HAL.PBB.AddBVLANToISIDPSIFail
Description
The message indicates the failure in adding a Provider VLAN to the floodin group of the VLAN or the I-SID. Lower the severity to narrow the cause of failures. The cause could be in the PSI library or the low on memory in the system.
Remedy
Retry the configuration so that the ports are re-added to the flooding group of I-SID or VLAN.
Severity
Debug-Summary
Message Text
Failed to add PNP ports of VLAN %vlanName% to the PSI of I-SID %isidName% when %info%.
Message Parameters
Name Type
vlanName String
isidName String
info String
Applicable Platforms
